Results 1 to 7 of 7
Thread: vats won't disable
    Dec 2004
    Port St Lucie, FL
    115
    vats won't disable
    '02 camaro ss. Been reading about this for years and it all seems straight forward. I pulled the tune from the car, changed the drop down selection from PWM to NONE, saved.
    Tried write calibration only.
    Tried re-write entire.
    Tried write vin/tunerlock/vats.
    Tried relink vats.
    After each try I put tape over the pellet in the key and it won't even crank over.
    Put the original tune back in and it's back to normal.
    What am I not doing right here? (or should I say whats left out of every how-to I've ever read about this?)
    Advanced Tuner Montecarlodrag's Avatar
    Nov 2009
    Pegasus Galaxy
    919
    Quote Originally Posted by JasonB View Post
    Change VATS to none. Save file
    Write calibration only, Nothing else
    Attempt to start.
    If it doesn't crank the problem is the BCM and you can't tune around it, because the PCM only cuts fuel, it doesn't prevent the engine from cranking.
    The BCM has the ability to disable the starter if the correct key is not used.
    9 sec Montecarlo SS
    Dec 2004
    Port St Lucie, FL
    115
    So it can be started with a remote start switch?
    Turn the key on, put power to the starter solenoid start terminal and it'll start?
    Nov 2009
    Pegasus Galaxy
    919
    Yes, if VATS is disabled it will start.
    You can also bypass the anti theft relay, it will let you crank regardless of the key.
    Why do you want to disable VATS?
    Much easier to disable the relay than a remote start.
    9 sec Montecarlo SS
    Dec 2004
    Port St Lucie, FL
    115
    Just said remote starter as an example.
    I have a spare engine I'm trying to run on the stand. I was just trying to get it to work on one of my cars as a test to be sure it'll run when I get my spare engine wired up.
    Apr 2009
    613
    On the fbody disabling vats in the pcm just means that the pcm is not looking for the fuel enable signal from the bcm. To disable the bcm portion you would have to rewire the starter relay.
    1997 Trans Am WS6 - LS1 swap - TR224 - Pacesetter Longtubes - Yank SS3600
    - 3.42 Moser 12 bolt - Wilwood Brakes - HP Tuners tuned - P1SC-1 Procharger
    Dec 2004
    Port St Lucie, FL
    115
    Thanks.
