Stock ls4 tuning questions.
Hello, just got my HPT and started scanning my engine. Engine may have old plugs and ill be performing a top clean shortly and changing the plugs.
While scanning I noticed the NB o2s were 870-890 in PE. I'm getting a few degrees of kr at part throttle and at wot.
Should I add to the Maff to get the o2s in the low 900s? Reason I ask is I used to have a supercharged Grand Prix and it always worked out best to run o2s in the 940 mv range in PE. Some day ill get a WB sensor but for now ill just have to use the stock NB.
Thanks!
Well did some more reading......looks like it's not even close when using NB o2 MV for a ballpark AFR.
Looks like I will be purchasing a LC1 WB to really get it there.
What's a good AFR for NA engines?
