Attached Original Tune & Original Tune but Setup for MAF Tuning via Wideband. Please confirm this is correct someone. Included a HP Scanner config file too.
I have my AEM wideband (after the cat) ........ which I believe is my problem as it's reading like 13.5afr at idle.... and the car is virtually stock but i cant get it infront of it, it's too tight.
No matter if I try lambda or afr error....... I seem to go way off the moment i make a change to the maf table etc..... and now after it all i'm totally given up......
HELP. See attached...
I have been doing steady state tuning but.... again it's after the cat converter. I'm not sure how to compensate for this or if there is something I have missed in my tune setting it up for MAF tuning.
Any comments? Do I also need to maybe set InjTempGain to 1.0 as well?
