Results 1 to 15 of 15
Thread: What causes extremely high IVT's?!
    Senior Tuner IDRIVEAG8GT's Avatar
    Aug 2010
    Roswell, N.M.
    1,956
    Did a log on my truck before I blew the converter up the other day and I noticed at an idle the Intake Valve Temp was sitting at 490*F.
    WTF? That isn't right is it?
    618/618 motor
    906/862 spray
    Tuner DGA's Avatar
    Aug 2012
    Indianapolis, IN
    97
    Assuming the Intake valve temp is a calculated value?
    I don't rape PE tables cause I don't know what I am doing anyway....
    Aug 2010
    Roswell, N.M.
    1,956
    Right. It's all calculated by what I think is how much fuel theoretically evaporates inside the intake port. I'm really not sure what the formula is to derive IVT but what I do know is that most of the IVT tables stop at 421*F. Something has definitely got to be up lol.
    618/618 motor
    906/862 spray
    Aug 2010
    Roswell, N.M.
    1,956
    I gotta be missing something.
    618/618 motor
    906/862 spray
    Senior Tuner 10_SS's Avatar
    Mar 2012
    Detroit, MI
    1,320
    I used to have IVT's I thought around 240's before my whipple.. now they are 300-310's... I thought normal were 240's. I did change the injector settings from the whipple tune to what is believed to be more accurate numbers but I didnt notice when the IVT's jumped up (after whipple, or after changing injector settings).
    It would make sense the whipple install alone would increase the IVT temps since there is about 30+ degrees higher intake air temp than ambient temp (the stock whipple cal reads 15 degrees low... check yours out see if yours is low too).
    EDIT: I take all that back... I just checked a log when I first bought my car (Stock), Im showing 330ish IVT going 80mph down the highway in 55f temps. I would still suspect your fuel injector settings since the fuel cools the valve... and if the pcm thinks there's less fuel hitting the valve.. then it will remove less heat from it.
    2010 Camaro LS3 (E38 ECU - Spark only). MS3X running complete RTT fuel control (wideband).
    Whipple 2.9L, 3.875" Pulley, kit injectors, supplied MSD Boost-A-Pump, stock pump
    LG Motorsports 1 7/8" Headers - No Cats, stock mid pipe with JBA Axle Back
    ZL1 Wheels/Tires
    Tuner blkscooby's Avatar
    Aug 2010
    Mesa, AZ
    81
    Did you scale the tune for larger injectors?
    Aug 2010
    Roswell, N.M.
    1,956
    Indeed IFR cut in half and stoich doubled for 114# injectors. ID1000's to be specific.
    618/618 motor
    906/862 spray
    Aug 2010
    Roswell, N.M.
    1,956
    Strange though. It has completely skewed transient and evap fuel coefficients.
    618/618 motor
    906/862 spray
    Advanced Tuner c.u's Avatar
    Jun 2010
    Eville, IN
    282
    May want to take a look at the ect sensor.
    Aug 2010
    Roswell, N.M.
    1,956
    ^ Lawl, 185! She's melting! Lol.
    618/618 motor
    906/862 spray
    Aug 2010
    Roswell, N.M.
    1,956
    Quote Originally Posted by c.u View Post
    OMG 185C=365F its getting a little warm. Now if you are standing in front of the car hood up motor running. It runs clockwise if your in the car the motor runs counter-clockwise.lol
    Nu uh it goes clockwise no Matter where you're standing because my motor is just a boss like that. Lolololol.
    Really though. Does an injector scale throw off IVT readings that much?
    618/618 motor
    906/862 spray
    Advanced Tuner Sébast19X's Avatar
    Feb 2008
    218
    I found this old threads....
    Hope this help a tad
    http://www.hptuners.com/forum/showth...&highlight=IVT
    Seb
    '08 Black Z06
    PCM Tuned, LG super RAM, AR Headers, Hoosier DR2 295-55-15, MSD Atomic air force intake, Iceman 7.0 cam
    Best N/A E.T. : 8.836
    Best N/A Mp/h : 159.75
    DA for this pass: 0'
    Advanced Tuner gn2beatu's Avatar
    Sep 2011
    Germantown WI
    414
    Why are you worried about them, they are just a calculated value. With 1500 degree chamber temps, the valves are goona be hot too! I dont think 390 is terrible, I have seen worse. Besides, valves transfer allot of heat to the head (via seat) that they soak up from the chamber.
    Is something fishy going on with the way its running, and your looking for why? Or you just curious why 390?
    2000 Regal GS ~ 3.25 Pulley ~ Headers ~ 3"ex ~ 1.85 Rockers
    Sold 06 TBSS ~ Front Mount T88 ~ 0-30 in 1.17 ~ 0-60 in 3.0
    Wanted ~ Engine-less 95/Older 4x4 ~ Jeep/S-10/Ranger for TT Project
    Aug 2010
    Roswell, N.M.
    1,956
    Quote Originally Posted by gn2beatu View Post
    490* not 390* that's at an idle. And that is supposed to be the back of an intake valve sir. Where fuel sprays on to the surface of.
    It throws off transient and impact factor fuel mass. (picks up a massive hesitation)
    My G8 sits around 300-330.
    618/618 motor
    906/862 spray
    Aug 2010
    Roswell, N.M.
    1,956
    Quote Originally Posted by Sébast19X View Post
    Seb
    That helps. So if an AFR value is referenced as stoich in this motor is commanded 29.XX
    That would quickly throw off any reported IVT readings.
    618/618 motor
    906/862 spray
