Hi guys. I have an off the wall project, it's a 1958 f600 that i have installed a 2000 6.8 v-10/4r100 in and, i cant get started. The first thing i have had done was to have disabled the security. I have correct fuel pressure, spark (will run on carb cleaner) and, i have 12v to the injectors, but i have no injector pulse. I have unplugged the tps and maf while trying too. Another issue is the fuel pump relay trigger wire from pcm only "blips" on the test light (power probe) when ignition is turned on and has nothing when engine is cranking. I can read rpm signal on my scanner with no faults that show any relevent problem. If anyone could help i would super appreciate it!
