Passkey II –
To perform a relearn on a Passkey II system, make sure there is a fully charged battery in the vehicle. The battery will be used for 30 minutes without the alternator available for charging. Connect a battery charger to the battery to ensure power is available while programming. Both
the BCM and PCM must be working and communicating with each other.
1. Insert ignition key and turn to the “ON” position. Do not attempt to start the engine. Leave the key in the “ON” position for approximately 11 minutes. The security light will be steady on or flashing for the 11-minute period. Do not proceed to Step 2 until the security light
turns off or stops flashing.
2. Turn the ignition switch to the “OFF” position for 30 seconds.
3. Turn the ignition switch to the “ON” position as in Step 1 for 11 minutes.
4. Turn the ignition switch to the “OFF” position for 30 seconds.
5. Turn the ignition switch to the “ON” position as in Step 1 for 11 minutes for a third time.
6. Turn the ignition switch to the “OFF” position for 30 seconds for a third time.
7. Turn the ignition switch to the “ON” position for 30 seconds.
8. Turn the ignition switch to the “OFF” position.
9. Attempt to start the engine.
If the engine starts and runs, the relearn is complete
