Yes I have the standard GM 1 bar sensor. So, I am lost, what would the HPT licence do for this? I didn't buy anything but the standard HPT package I thought.
I don't rape PE tables cause I don't know what I am doing anyway....
DGA your sig= lololololol
618/618 motor
906/862 spray
I would guarantee you've got a wiring issue somewhere. If the PCM is saying 300+ kPa for baro pressure, it's seeing ~15v on the input. How something isn't damaged, I have no idea.
http://www.dsxtuning.com
Just say no to bull s***.
I swapped the 5V and signal pins over and tried that. The ground is the ground so should not be a problem. I got a really low, -10 Kpa reading like this and it would not change, looking at it later it destroyed the MAP sensor. Tried pulling a vacuum on the other original GM sensor, with key on, engine off the MAP signal is still 335 Kpa, when you pull a high vacuum on it, it goes to -15 or so. Sucking on it by mouth you get low as well, about 10 Kpa. Strange.
Is there a chance the ECU has a bug in it's firmware or something? I have not checked the 5V when running the engine is the only other thing I have not tried.
