I have made progress with the high MAP readings on this aircraft, LS1, E40, turbonormalised (no boost), by lowering the Engine diag, Airflow, MAP sensor Linear, Offset and Linear B settings. They were originally set the same as the '05 GTO in samples that came with HPT. These were 94.43 Kpa, 10.33 and 31.48 for the three settings. I lowered them all to 70% of that, but made sure the Linear B one was 1/3rd of the Linear value. It is close now, the MAP still goes over 105 but stays in the vacuum range under that most of the time, and the motor runs much better, much more responsive etc.
So, I really don't know if I did the right thing, have I screwed up the slope, the offset or what should I have done to get the MAP to not read 335 Kpa when the engine isn't running, and around 240 with it running? Can someone explain how these settings work and why I might need to lower them?
