Results 1 to 18 of 18
Thread: support for f-350
    support for f-350
    hello did a read friday night on a f350 with 5.4l. read out alright but gave ome index out of bounds.
    will these be supported in the near futute
    Tinmaster_f350.hpt
    97 k2500 ecsb 5.7l/4l80/4x4 0411 pcm,thorley tri-y's,true duals(no cats),msd ign.,zz4 cam, tuned with efi live
    28,292
    Its already supported in 2.24
    Feb 2006
    South Carolina
    1,525
    Is it possible there may be an issue with the template? I'm getting a lot of erroneous values in the editor and some blank "Switches"
    Using version 2.24.227
    Jaime
    28,292
    anything is possible, I can't open files on this pc but if you send me an email reminder I can have a look in the morning on my work pc.
    28,292
    Took a look at the file and to me it looks like the file in the pcm is just screwy, I'm pretty confident each and every table & switch in that def isn't wrong
    ya read was from f350 didnt think it was even going to work, but read out just doesn't look right and gave error messages
    just down loaded latest version and still lots of blank switches
    28,292
    tokymon its likely NOT a software issue on our end as stated in my post last night. I'll have our ford engineer take a look when he has a moment though as I don't have a stock file with that operating system to test.
    Dec 2009
    1,084
    Quote Originally Posted by tokymon View Post
    I would get a Fresh read with the Latest Software you have now and see if it errors when downloading and if it is still corrupt.
    Wondering if it is possible that with older software that did not recognize the Truck correctly that it may have corrupted file?
    Not sure if that possible or how old your software was with original read.
    Feb 2006
    South Carolina
    1,525
    Quote Originally Posted by planethax View Post
    I agree with this.
    Jaime
    28,292
    Not likely, while I'm not a reverse engineer I've seen this before when the vehicle was previously tuned poorly. My own personal car had a similar issue. Fixing it required me to find a stock file & write entire.
    this is a stock truck never been tuned before.
    28,292
    thanks Tokymon I'm having our ford engineer look into it.
    28,292
    Try redownloading & reinstalling this mornings build 2.24.235 or newer
    will do. wont see truck till tonight.
    Feb 2006
    South Carolina
    1,525
    Using the file he posted above, that looks much better.
    Jaime
    28,292
    Yeah the def got mixed up with another one, switched them around and all good again
    It Worked.
    thank you
