I understand that 1.00 is optimal Knock learn and 0.00 is running off the low octane table. And in between is a blend of high octane table and low octane table. I've read a bunch of stuff on the Camaro forums about being stuck on the low octane table with the Gen 5 camaros. And people try to reset by pulling the fuses.
I have a 2012 ZL1 and was curious what the Knock learn factor was so I scanned the car today and the KLF is all over the place. So I scanned all 8 cyl for knock learn. Some are bouncing all over and some are somewhat fixed at .26 or there abouts. Curious thing is all the odd # cylinders are the fixed ones and the even # cylinders are bouncing all around. So why is this. I tried pulling the fuses for the PCM and no change. Tried disconnecting the battery and no change. Now I have the battery disconnected and leaving it that way over night. But I expected pulling the battery would reset all the Knock Learn to 1.00 but that doesn't happen.
I'm attaching the log file from this afternoon
