I'm planning to set my tune to be MAF only. I have read some use STFT's only, others use LTFT's only, and then there are some who will scan LTFT + STFT simultaneously and and make correction to MAF Hz table.. I assume trims definitely must be reset before scanning, as well as DFCO, COT, and DOD disabled. Afterwards, some will disable or enable LTFT's afterwards, not sure why LTFT's are not wanted except for changes they can make when entering WOT. This vehicle is a daily driver that honestly, will not go into WOT very often during my time with it. Any expert advice on differences between scanning with LT, ST, or LT+ST and disabling LTFT's after MAF closed loop tuning. "Wideband" part throttle tuning is not an option as I use a tailpipe sniffer and will only use it for WOT tuning.
