I need some help with cruise and most importantly WOT/PE and LTFT's
I just installed my Whipple kit on my bone stock 2010 Camaro LS3, and installed the stock whipple tune, then copied it out and applied everything to a 2bar OS, with ZR1 sensor.
Everything went great, it feels like it runs perfect and I dont see any knock, no codes, I have not went WOT higher than ~3500rpm since I like to take things slow and make sure they are working. at 3500rpm WOT Im at 153kpa and 1.02 g/cyl... Stock I would be lucky to pull ~0.78g/cyl at max anywhere in the RPM curve so I know the Whipple is working.
From what I see, before entering WOT/PE, Bank 1 and 2 LTFT are split a fair amount (7.8%), and going into WOT this is causing problems, or the other possibility is whatever the problem is causing the split LTFT is carrying over into WOT, causing Bank 1 to be much leaner than Bank 2 at WOT. Below is the info:
At normal driving before Frame 11984 (my WOT split LTFT example):
--------Frame------PE Mode----LTFT------o2 mv
Bank 1--<11984----NO----------~7.8%----Normal swing
Bank 2--<11984----NO----------~0.0%----Normal swing
When I enter PE around frame 11984, the LTFT switch very low, and Bank 1 goes lean but is still much higher (6.3%) than Bank 2 and is very lean:
--------Frame----- PE Mode------LTFT-----o2 mv
Bank 1--=11984-----YES---------~1.6%----100mv (eeek)
Bank 2--=11984-----YES---------~-4.7%---800mv (still lean)
So, I can see I'm still lean any way I look at it, but... why would you think my LTFT are split so bad, or is this normal with the Whipple?
Since I am lean on both banks as it is at WOT... would richening up overall at WOT help bring both O2's up closer to each other (I know 02's aren't great for other than 14.7, but I also know they are somewhat ok to use to see both banks around 800-950's.. far away from 100 and 800mv), keep in mind I would not catch this with a single Wideband and why I like to check NB02's simply to make sure things make sense.
Also what would the best way to increase the tunes overall fueling... add 5% to every MAF table entry as this attached tune is 100% MAF? It seems a bit lean everywhere based on LTFT. This morning they were all ~6-8% adding fuel, later today they are around 3% adding fuel.
Thanks for any help.. this is stumping me!
