I ran a few 2nd gear WOT runs this evening. I am commanding 12.5 AFR for the entire rpm range in PE mode. In the 1st run, my wideband is showing about 11.8 ish AFR for the entire run instead of 12.5. I havent adjusted MAF with wideband yet, so I assumed that this was due to the MAF output showing more incoming air than actual. In the 2nd and 3rd runs, AFR was same 11.8 ish instead of 12.5, but strangely right at 5000 rpm the wideband shows AFR slowly rising all the way back to Stoich, all while at WOT. Nothing changed between 1st, 2nd and 3rd runs. Just a couple mins between them? What gives?? I did a "read entire" to make sure this tune was installed. I attached runs and latest tune. Scroll to end of run1 to get to WOT scan. Any help appreciated.
