Idle clip from this morning, when I got to work. It idles better in gear.
http://youtu.be/OTxiIqL9B-Y
Oh you're Enginerd off the G8 forum aren't you? License plate gave it away
Sounds good to me, now you need to time your injectors to the cam (so do I) and rid yourself of that crappy axleback setup. I hated my Magnaflow as it sounded like that too, till I changed to this:
http://www.youtube.com/watch?v=Rth8K...g&feature=plcp
618/618 motor
906/862 spray
Hmm, I was about to say, I didn't know you (assuming you were the other person) had cammed your car.
Eh, I hate the plugged up popping sound at idle, that's essentially from tip resonance which is excessive back-pressure created at the Y in the tips. It hurts performance, but not enough to care about if you like it like that.
Have you looked into injector timing?
618/618 motor
906/862 spray
Yeah, it added 13* to the EOIT boundary last week and it seemed to cut down on the raw fuel smell but it also changed the exhaust note. Not sure where it should ultimately end up, hopefully someone else can help. I read through the whole Gen 3 thread discussing it but it was very helpful for tuning a Gen 4.
PM sent.
618/618 motor
906/862 spray
Pay close attention to when your intake valve opens and when your exhaust valve closes.
http://www.dsxtuning.com
Just say no to bull s***.
That's what Steck and I are discussing.
So you added degrees to the boundary target to clean up the fueling? I always tried to retard it. Maybe that's why it seemed to get worse when I messed with the boundary target
618/618 motor
906/862 spray
Ehh, bored at work today, soooo...
I attached a spreadsheet that calc'd my valve events but the summary is
0.050" lift closed
IVO- 354.4 IVO- 327
IVC- 573.5 IVC- 602
EVO- 129.5 EVO- 103
EVC- 362.5 EVC- 398
Stock EOIT normal, warm engine, at idle is (520-110)=410* ATDC. My new target is (533-110)=423*.
Quote from Chris on LS7 injection tables( same logic as the G8), borrowed from the EOIT thread...
Quote:
Boundary is the latest point in time that fuel can make it into the cylinder for the current injection period. It is measured in degrees AFTER TDC compression. It is also the earliest the injector can fire again after the completion of the last injection event. ie. the boundary defines the start/end of a complete injection cycle.
Normal End of Injection Target (EOIT) is the angle before the boundary (in degrees) that the normal pulse (the main pulse) should finish. The hardware calulates the start of injection time from the EOIT and the desired PW.
Makeup End of Injection Target (EOIT) is the angle before the boundary (in degrees) that the first makeup pulse should finish. Makeup pulses are extra pulses that can be injected to inject more fuel during an injection cycle rather than having to wait for the next cycle. There can be more than one makeup pulse but the makeup EOIT specifies the EOIT of the first makeup pulse.
The makeup PW minimum is a minimum PW for the makeup pulses, they cannot be shorter than this (if they are they don't happen).
So you have the boundary that defines the injection cycle, a normal EOIT that specifies the EOIT for the main pulse, and finally a makeup EOIT that specifies the EIOT for any makeup pulses that might be needed if a fuel increase is commanded during an injection cycle but after the main pulse has occurred.
Hope that helps.
Chris...
Now that I have the idle airflow fixed and the low end MAF correct, I pushed the EOIT out to 20* advanced and the car is awesome. So I'm not quite sure how to get from cam overlap to required EOIT advance, but 20* EOIT for my 8* overlap cam works great. Just have to fix an exhaust leak and I'm on to E85 tuning.
20* may not be mathematically perfect, but definitely a step in the right direction. I think you mean you retarded EIOT though. Advancing would be spraying sooner and losing more through the exhaust valve.
Ideally, 0.006" events should be used if you really want to get great results. Bigger injectors give more flexibility too because of the drastically reduced crank rotation of the firing.
618/618 motor
906/862 spray
Look at the modifiers and read the descriptions.
This is simply the boundary minus the normal. I pushed the boundary so that it affects both the normal fuel pulse and any makeup pulses. I could have adjusted the normal but low RPM was 0* and I wasnt sure it would work with a negative value here and the makeup pulses would not have been shifted.
