Recently, while having tuning done on a dyno, the heads lifted and water was pushed. I am trying to determine what caused this to happen so I can avoid it from occurring again. Some guys have told me that detonation caused it, others said it was the 20 pounds of boost with stock head bolts, along with high IAT2s (210). After the heads lifted the plugs were checked and I was told no signs of detonation. I was also told the compression was ok. The tuner sent me only two of the logs (out of 5 or 6 dyno pulls). Supposedly one was when the heads lifted, the other was the preceding pull. I found some knock at around 5400RPM on one of the logs.
I heard that this tuner often reduces the knock sensitivity (this may be normal?) so I decided to compare the values of a stock tune vs. the current tune. This is what I found -
Knock sensor Threshold Init
Stock = 120.0195 for all cylinders
Tuner = 179.9805 for all cylinders
Burst Knock Retard vs. Cylair Delta
Stock = values ranging from 2 to 12 from 0.012 to 0.048
Tuner = All values set to 0
Knock Sensor Threshold Min
Stock = Voltage 50.0000 for all cylinders
Tuner = Voltage 150.0000 for all cylinders
Knock Fast Recovery Rate vs. Cylair Delta vs. RPM
Some values were changed (I'd have to scan as an attachment as too much to type)
BTW - I have a 09 CTS-V, auto, 11k miles, 2.9 whipple, mild cam, HX, full Stainless works exhaust.
I would greatly appreciate your comments, thoughts , concerns.
Thanks.
