hey guys ive been on the forum for a while but this is my first post, definitely a noob to all this ive been trying to read as much as i can on everything to get a better idea of whats going on behind the scenes with the programing. Im a little lost at this point, i have widebands installed and the maf disconnected and the maf fail set at 0 and to the best of my knowledge all the other things needed to start ve tuning. My issue is i have the afr error chart, after a drive, giving me %'s all over the place, i did the copy and paste special multiply by to the ve and flash. ON the next test drive the numbers on the afr error are coming up almost identical and some of the adjacent cells in the ve are almost double that of their neighboring cell. Ive tried tuning this way a couple times with the same outcome and the car is still running lean on accel and rich on decel and im unable to get to the commanded afr. I've adjusted the IFR as to the best of my knowledge for the bosch green giants (0280155968) according to numerous threads on this forum and some others with the help of a spreadsheet. Any help is greatly appreciated, thanks in advance,
mike.
list of modifications:
99 camaro z28 ls1
383
Trickflow 215 heads
Trickflow cam 228/230 585/585
Harland sharp roller rockers 1.7:1
Bosch 0280155968 injector(42#@3bar)
Ls2 fuel rail
Racetronix fuel pump (in tank 600wtq) (62psi at the rail @idle)
Fast lsx 102 intake
92mm tb
Stock maf w/ 4" intake tube
Stainless works lt headers 1-7/8
primary 2.5 collector
Custom cat-less y pipe w/widebands
Borla catback
Slp high vol oil pump and timing chain
Set. Adjustable advance set at 0*
All stock sensors
car is a 1989 trans am gta
