I got a swap using a 2010 Camaro PCM and a T56 tranny. Car will crank and run for 2 seconds. I thought I had all the codes deleted and I did write entire but could you guys look and see what I missed. The car is not in my possession so no scans.
Try disabling the Starter check as well as the VATS
I thought I had, what did you see I missed?
Does it have a good MAF and MAP signal?
2003 Chevy Silverado Daily Driver, 408 Iron Block,
LS3 Heads/Intake, 231/239 114, 4L80e, Yank SST 3200.
FYI Starter Checks are still enabled. not sure if that would do it or not?
After doing a write entire, do a read to be sure the entire write actually took.
