if there is fuel in the cylinder it acts as a fluid seal on the rings during the test.
testing ring leaks is as follows: perform dry cylinder test. if numbers are low put a few squirts from an oil squirter into the cylinder and perform test again. if the numbers rise then the oil is sealing the rings up and restoring the compression.
