its cutting fuel/spark at 4000rpm disabled all torque managment maxed out everything i could find
I dont have a vss signal which proabably has a lot to do with it
not on my tuning laptop therefore i can not view the file, but if your on a automatic OS, (being a 5.3 you likely are) they have a P/N rev limit of 4000 rpm... raise those values
Owner of Cunningham Motorsports
06 z06
2016 camaro
68 Camaro
2014 e63 amg
07 LBZ Duramax
im using a manual corvette os
I did a write entire and I got it to rev past 4000rpm. The next time i drove it after I shut the car off it started doing it again. Any Ideas?
Is your neutral limiter set to 4000 rpm? (rpm by gear)
Also, for rev limiter you have to go into speedo ---> limiter and set the source to 'calibration' and not GMLan. That may be causing your issue.
2011 Camaro SS. LS3/630rwhp n/a
Under engine -> torque management -> general, take a look at the Default Trans Limit table.
I count sheep in hex...
It keeps doing the same thing. Is there something im missing?
read my post above and change the table. Your OS is from an auto, see Trans -> ECM Trans Type.
The ECM has lost comms with the TCM and uses the Default Trans Torque Limit table.
Chris...
under torque management I have everything maxed out and disabled, under trans it does not show ECM type just manual c.a.g.s
And in the "Default Trans Limit right at 4000 rpm your set at -37
You have everything BUT the "Default Trans Limit" Table
max it to 6042 across
I have the view on advanced and im still not seeing default trans limt
please email support for access to the latest beta software.
