Taxied this plane around today. It would get to some point then go into low power mode, limp home mode for some reason. The MAP readings on the log I attached show up to 273 kpa, which seems almost three times as high as they should be. The VE map only goes to about 105. This thing has a large turbo (1.48 A/R) but is not making any boost and is just idling over at these low engine rpms. I set up a boost PID in the log and it shows 30 psi of boost at 1200 rpm, no way in hell could it be doing that, and show no KR. Lost as always, anyone have any ideas?
