Timing
Is 28 degrees at WOT all in one value,is that ok in my 2001 camaro
please be more clear, so we can help
you should ask questions about the 2001 camaro in the GenIII section.
usually the timing value fluctuates depending on knock retard, combustion temps, etc. may older carburated cars like small blocks from the 60s would run on 30 degrees of timing at all times, some had vacuum advances, etc. my race car timing is set to 30, for example. It starts on 30 degrees, it idles and races all at 30 degrees.
so it could be feasible that 28 degrees through WOT could be ok. It's probably not perfectly ideal though. it all depends on the rest of your combination, what fuel you run, compression, etc.
