2008 5.3 76mm front mount turbo. Have not pulled a scanner file yet, just got software.
Thanks in advance!!!
PE Enable TPS is way too high. Lower it down into the teens and raise your enable MAP.
What injectors are you using?
I am running FAST 57/60 injectors.
I probably need to enter the correct injector data.
Bump
