Results 1 to 9 of 9
Thread: E38 Calibrated Success Problem
    Jan 2007
    34
    I just finished watching Calibrated Success GM Beginners Guide, and after setting up histograms, and sensors just as described in the DVD I get Unsupported Parameters as soon as I start to record. Has anyone else had this problem, and how did you fix it?
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,261
    Post your scanner log, config file you are running as well as your VCM Scanner.cfg file(which stores your custom pids).
    Jan 2007
    34
    Here is the configuration. There is no scanner log since it goes to unsupprted parameter as soon as you start to scan.
    Jan 2007
    34
    Scanner cfg
    Tuner in Training Mark Wheeler's Avatar
    Mar 2011
    14
    You need to insert Air Fuel Ratio Commanded Hi Res to the primary table before it will work.
    Just right click on an open area in the primary table and click on Insert/Fuel System and then double click on Air Fuel Ratio Cammanded Hi Res.
    Should fix it.
    2009 hot white G8GT - Vararam, HSRK, street tuned, Kooks longtube headers and x-pipe. 12.675 @ 112.05mph.
    Jan 2007
    34
    Quote Originally Posted by Mark Wheeler View Post
    Should fix it.
    That did it. Thanks.
    Mar 2011
    14
    Yeah I had the same problem and like to have never figured it out. That information was left out in the video. Or I missed it! lol
    Jan 2007
    34
    I'm fairly sure it was left out. I watched it about 10 times looking for what I missed. I was logging my user defined commanded afr, and that doesn't work.
    Jul 2012
    Nashville TN
    13
    We also had the same trouble, we added AFR hi-res to tables works fine now!
