Ok, had a customer bring me a car 'setup' to run a 2bar OS. Setup a base file just to check everything over and found the MAP sensor was reading 140 or so kpa at KOEO.. This was with the 2bar MAP PID.
Checked my linear and offset settings and am at 200 and 8.32.
Looked at the physical sensor and there was no label or anything else. Sooo I gave the customer a number I found on here, and he showed up with a different part number all together. He stated that the parts guy told him the number had changed to this one.. AC Delco 12614973
With this sensor, I see 120kpa at KOEO..
Is this not a 2bar sensor or is am I supposed to be using different offset and linear values for the sensor?
