Results 1 to 8 of 8
Thread: Invalid Vin/OS Pair Error message on already tuned PCM
    Aug 2012
    47
    I've sent an email out as per instructions, but my question is this; the PCM has a wait4me tune already on it. Am I getting this error due to the tune? If so is there anyway to fix it on my end?
    Aug 2012
    47
    Also I installed 2.23 Beta and it took the application key, but when I tried to go to 2.22 suite it asks for the application key and says it's invalid. I'm copying and pasting it directly from the email.
    28,290
    Having the pcm flashed to a valid vin/os pair via tech 2 & then rereading with our software will usually work.
    Mar 2011
    Texas
    10
    Same Problem
    I too am getting this error. Here is the file. Any help is greatly appreiciated.
    Advanced Tuner Shrek's Avatar
    Nov 2011
    753
    The tune you posted has a 2003 VIN and a 2006 OS - you need to change one of these. The VIN (year / vehicle) must have a corresponding OS originally offered in that year, with that vehicle platform.
    Mar 2011
    Texas
    10
    Thanks for the reply, Im guessing the only way to fix this is to find a tech 2 and reflash it? Like mentioned in the above post.
    Aug 2012
    40
    Im running into the same exact issue right now i already had it tuned twice once mail order 2nd dyno tuned now i have to find someone who has that scanner
    Nov 2011
    753
    Quote Originally Posted by hicksport View Post
    You have a couple of options. A full reflash to stock with a Tech 2 / Tech 2 type device - from a GM dealership or tuner who owns a Tech 2 / Tech 2 type device.
    Or, given the VIN OS mis-match, the PCM has already been flashed with non-HPT software. Take it back to where you got it - and have it reflashed with a matching VIN OS combination.
