I'm having some issues with a XLR-V that has a D3 pulley kit. No matter what I do, I can't get it to boost above .77 bar (11 psi). The pulley is supposed to bring boost up to 15 psi. I set the boost map enable and disable values up higher (210 and 230), I turned up desired torque under the supercharger section of TM to the highest values for 85 and 100% throttle (going off of memory here). I'm beginning to think that there's a mechanical issue and not the computer pulling boost, unless there's something I missed. Anyone have any ideas? Thanks!
