Results 1 to 17 of 17
Thread: LS7 with LS9 injectors. Switching to vac referenced regulator
    I have an LS7 with LS9 injectors. I plumbed the fuel system with a firewall mounted Aeromotive regulator and would like to try running with with manifold vac reference. I have read several posts on this, but would like to make sure that I am doing this right. First, set the base fuel pressure to 58 psi and set all cells in the IFR table to 56.4 lb/hr. Should I set the Offset Select to MAP instead of Vaccum? The Offset vs. volts vs MAP table is all zeroed out. Should I copy values from the Offset vs. Pressure vs. IGNV at 58 psi column to all columns in the MAP table?
    TIA.
    Senior Tuner IDRIVEAG8GT's Avatar
    Aug 2010
    Roswell, N.M.
    1,956
    56.4 lb/hr? LS9's flow 52.5 lb/hr at 58psi.
    618/618 motor
    906/862 spray
    Quote Originally Posted by IDRIVEAG8GT View Post
    Hmm. Really? I must have been given a spreadsheet with misinformation. No wonder it ran a little lean when I put the LS9 injectors and values in. Do you have the correct spreadsheet for the LS9 injectors?
    It's interesting that Lingenfelter lists the LS9 injectors at 56.4 lb/hr at 58psi. http://www.lingenfelter.com/mm5/merc...egory_Code=C77
    Am I missing something here?
    OK. Found this.
    http://www.hptuners.com/forum/showthread.php?t=37484
    It looks like there is a lot of bad info floating arround about injectors. I changed the IFR table to 52.5
    Now back to the original quesiton. So I set the offset option to MAP instead of Vac and then modify the Offset vs. volts vs MAP table? Sound right so far????
    Aug 2010
    Roswell, N.M.
    1,956
    You're on the right track now.
    If I could see your tune I'd be happy to tell you but right now I'm on mobile. Hopefully Dave will chime in real quick and at least provide a thread to research.
    618/618 motor
    906/862 spray
    OK, so here's what I have done so far. I changed all the IFR cells to 52.5 lb/hr. I put the offset select back to Vac. I downloaded a ZR1 LS9 stock tune file for reference. In that calibration, the Offset vs Press vs IgnV table doesn't have a column for 58psi, so I interpolated between the 56.3psi and 59.2psi columns to get the values for 58psi and pasted those values into every column in my LS7 tune file. The result is attached.
    Thanks for the help and feedback.
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,859
    Copy the injector data from this file and be done with it.
    http://www.dsxtuning.com
    Just say no to bull s***.
    Got it. Thanks!
    Aug 2010
    Roswell, N.M.
    1,956
    Thanks Dave. (Even though he says mean stuff and hurts my feelings all the time, he covers my ass when I request it.)
    618/618 motor
    906/862 spray
    I used Dave's injector #'s and it seems to be working well. Thank you!
    Dave,
    I noticed that most of the offset #'s that are in the data that you provided are the same as the ones I got from interpolating between the two columns in the LS9 stock tune, but a few are quite different. Would you mind sharing how you came up with them?
    Thanks,
    Joe
    Mar 2008
    St. Louis, MO
    4,859
    Polynomial regression of the LS9 offset table.
    Aug 2010
    Roswell, N.M.
    1,956
    What he means is that he used either a spreadsheet or calculator to come up with differences per section compared to the offset of the axis(s)
    618/618 motor
    906/862 spray
    Mar 2008
    St. Louis, MO
    4,859
    No, I mean I wrote my own Excel spreadsheet to find a polynomial representation of the offset table, and used it to calculate values for any axis label I choose.
    Aug 2010
    Roswell, N.M.
    1,956
    Same dif, lol at least it works the same way.
    618/618 motor
    906/862 spray
    Jun 2015
    6
    can you attach the file ? i need the data also , thanks
    Tuner in Training c4love's Avatar
    Feb 2014
    Texas
    35
    Anyway you could share this injector data again DSteck? I found the Zr1 excel sheet on another thread, just got a bit confused reading through some of your responses on calculations for running this in a c6 z06.
    Thanks for your time! I know this is an older post.
    Dec 2008
    Kingston, Rhode Island
    40
    Did you get this worked out? I would love to see the finalized numbers for the LS7 using Ls9 injectors
