I have an LS7 with LS9 injectors. I plumbed the fuel system with a firewall mounted Aeromotive regulator and would like to try running with with manifold vac reference. I have read several posts on this, but would like to make sure that I am doing this right. First, set the base fuel pressure to 58 psi and set all cells in the IFR table to 56.4 lb/hr. Should I set the Offset Select to MAP instead of Vaccum? The Offset vs. volts vs MAP table is all zeroed out. Should I copy values from the Offset vs. Pressure vs. IGNV at 58 psi column to all columns in the MAP table?
TIA.
