So help me figure this out, when I first built my LSX I installed a 227/239 .614/.624 on a 115+3 cam. (Look familiar Steck?)
After tuning it thoroughly my fuel trims stayed damn close to zero.
Well I decided I needed some more top end so I changed the cam to an off the shelf Lunati grind.
It's a 227/239 .651/.651 on a 112 with no advance.
In basically the same weather conditions I noticed my fuel trims had come to about -13% around idle and cruise. This cam sports 9 degrees of overlap, and I changed absolutely nothing to the induction system at all.
Is it because the cam makes less torque down low that it wants less fuel? Or does it have to do with overlap. I figured it'd require more fuel especially with the additional lift. WBO2 cofirms the need of less fuel.
Funny thing is, it doesn't buck/surge/anything. As soon as its over 1,100rpm the exhaust note is crisp and sharp, but around idle, well sounds hungry.
Anyways what do you guys think about that? Any theories/suggestions?
