What idle parameters should I even be concerned with running full time SDOL?
It seems as though some of these would have to be calculated by using a MAF, which I do not have.
You use the same idle tables in SD that you use in MAF.
EFI specialist
email=[email protected]
So how is RAF calculated?
MAP sensor and...? Is it just calculated against your cylinder volume?
