Results 1 to 10 of 10
Thread: how to view max injector duty cycle
    Aug 2012
    7
    so since ive been tuning to look up where my duty cycles are i just scroll through the chart and find what i'm looking for.
    i was told by a friend that hes pretty sure there is a way to just view what your max duty cycle is. he also said that he's seen someone put it in a histogram.
    i tried to figure it out on my own for a bit but i figured insead of getting frusturated i'd just ask .
    thanks!
    28,265
    max duty cycle of what? Its all relative.
    Your duty cycle could go past 100%.
    Most will say to stay under 80% at wot as this is around the point where the drivers start loosing a bit of control over the injectors.
    Aug 2012
    7
    Max injector duty cycle.
    How do i put it in a histogram Or maybe in the gauges window if possible.
    Or just see the highest value in % (really the only one im interested in)
    Ive beenusing the charts but its time consuming.
    Jun 2007
    Finland, Europe
    549
    Go to Histogram settings.
    Select empty one.
    Click PID line and select Injector Duty Cycle (from the bottom..). If you want, create a custom filter as well.
    Save.
    Note: you may need to select something for the row and col axis. I don't have Gen IV stuff now avalable for a screenshot and I'm using beta anyway, which is a bit different from Histogram conf point of view I think.
    Mar 2007
    Tucson, Az.
    165
    If I understand you correctly, you want a histogram or gauge to automatically show you the highest % of injector duty cycle reached during a log file. As you probably know, that can be done with the various gauges in the scanner like RPM, etc. However injector duty cycle is not a selectable parameter in gauge configurations.
    And the normal options in histograms is average, last and count, not highest value. Lastly I am unaware of a filter that shows highest value. I might be wrong.
    Nov 2005
    Houston, TX
    3,968
    IDC is an available PID to select when creating a gauge, histo or chart. As long as you're logging injector pulsewidth for both banks the IDC PID will calculate it for you.
    Bill Winters
    Out of the LSx tuning game
    Aug 2011
    Alaska
    566
    I have a gauge set up for duty cycle.
    When arguing with an idiot, make sure he isn't doing the same thing....
    Aug 2012
    7
    Quote Originally Posted by jim2092 View Post
    How do i put average in a gauge?
    That would work because gauges show the max value eith the outlined pointer.
    Mar 2007
    Tucson, Az.
    165
    5 Liter Eater and Michael D are right.
    Open your scanner>open gauge display>right click with the cursor on the gauge display>left click on the parameter that you want to replace with injector duty cycle>left click on PID:> left click on Inj. duty cycle. Make sure you check Draw Max. and have both Inj. Pulse Width Avg. in your table display.
    Hope this is clear.
    Aug 2012
    7
    Hope this is clear.
    Worked Perfect!!! Thanks
