So i just picked up this car, its got 150kms on it and seems to be in pretty good shape. I haven't pulled it into the shop to get into much yet but i did find that it has a K&N filter in the stock box and there were 3 or 4 honeycombs smooshed in the MAF. I straightened them out as best I could, not sure if that is a big deal or not. This is the first car I have had with a MAF. The guy sold it cheap because he thinks there is a transmission problem but I was thinking its the MAF needing some cleaning. I sprayed it with carb medic, and cleaned up the air filter, took it for a drive and noticed tons of knock and fuel trims.
Oh i did throw half a can of seafoam in there, maybe it is causing the kr?
So how would one go about testing parts out?
Would a K&N make it that lean?
I don't know if i'm going to keep it yet so I probably won't tune it yet, and it should be in good condition before i start anyhow.
I have the dtcs that were on it from before with the stock tune and the config i used. Also if someone has a set of histograms and a config that works well for this car i would really appreciate it
Thanks, Mark
