Page 1 of 2 12 LastLast
Results 1 to 20 of 21
Thread: Throttle closing at shift
    I started tuning on my 2012 Cruze 1.4t/A6 today. After flashing the tune in, am getting some throttle closure at the shift points. I am assuming this is some kind of torque management? Can somebody point me to the tables I need to be looking at? Thanks.....
    2012 Cruze 1.4T, mods to come.....
    1994 Chev Work Truck 6 liter with PT76GTS/4L80e
    1993 S10 Blazer AWD 6 liter with LS3 heads/4L80e
    Advanced Tuner projectlnf's Avatar
    Jun 2012
    warrenton va
    479
    Quote Originally Posted by l-eater View Post
    my HPT wont open your tune file
    but i think on an automatic car it closes the throttle so the trans can do its thing and shift gears so its not banging off the rev or reving out and destroying the internals in the trans... if it didnt do it it would be like me no lift shifting 100% of the time in my cobalt... not good! lol thats my thought on why it would be closing
    2003 Ford excursion 6.0 PSD
    No limit intake
    Straight pipe
    Studded
    EGR delete
    KC billet single plane compressor wheel
    Self Tuned
    XDP Regulated return
    RDP Fuel sump
    AEM progressive water meth
    Custom suspension air bags
    8" lift
    35" tires
    Yeah, I'm pretty sure they have it closing to protect the trans but it doesn't do it with the stock tune so I am thinking there has to be a table that has torque limits I am now exceeding or something along those lines?
    Jun 2012
    warrenton va
    479
    ahhh i see so your on a modified tune.. yeah if the cruze is anything like the lnf ecu.. it will use a combo of throttle closing/opening, timing, and the wastegate to get the torque your asking for. but i cant even look at your tune so i cant see whats going on? lol
    No limit intake
    Straight pipe
    Studded
    EGR delete
    Self Tuned
    RDP Fuel sump
    8" lift
    35" tires
    Dec 2009
    1,084
    I am getting a file fail validation check as well.
    Unless we need latest beta (cruise is new? )
    I have .647 right now
    Jun 2012
    warrenton va
    479
    Quote Originally Posted by planethax View Post
    i just got my hpt cable like 3 months ago is there a new update since then?
    No limit intake
    Straight pipe
    Studded
    EGR delete
    Self Tuned
    RDP Fuel sump
    8" lift
    35" tires
    Dec 2009
    1,084
    Couple times a week the beta is updated
    Jun 2012
    warrenton va
    479
    hmmm i see lol
    No limit intake
    Straight pipe
    Studded
    EGR delete
    Self Tuned
    RDP Fuel sump
    8" lift
    35" tires
    Yeah, I had to get the newest version as of last Monday to be able to tune this thing
    Jun 2012
    warrenton va
    479
    mine is being weird... my version is 2.23.474... but my computer has .net framwork 4.0 and it will wont download and install the new beta
    No limit intake
    Straight pipe
    Studded
    EGR delete
    Self Tuned
    RDP Fuel sump
    8" lift
    35" tires
    Dec 2009
    1,084
    i updated and can now open, pro you have pm
    Jun 2012
    warrenton va
    479
    got it man thanks alot! i also found they moved some stuff on my lnf.. i like it lol i just cant wait for them to come out with new tables..
    but ill look over this tune and see if maybe somewhere there is a way to change this throttle plate ordeal
    No limit intake
    Straight pipe
    Studded
    EGR delete
    Self Tuned
    RDP Fuel sump
    8" lift
    35" tires
    Jul 2012
    Columbus, OH
    83
    Where do you find the new versions for the beta software?
    Dec 2009
    1,084
    Quote Originally Posted by LNFnewb View Post
    you email support at hptuners.com with your serial#
    They will then put a link to it on your customer page
    I studied some more today on my logs to see if I could determine why the throttle is closing. It starts closing before the shift and doesn't go full throttle again until it is completely in the next gear. I just dont see anything spiking that would throw up a red flag. I tried turning off the traction control (with the button on the dash) and it still does it. Also tried manually shifting and it still happens. I can go back to stock and it stays full throttle no problem.
    Jan 2009
    Kalamazoo, MI
    14
    Your Driver Demand Map's are lower than mine ( I have a M6) Try upping the driver demand a small amount in the last row. (100% Throttle position) the test to see if it helps your issue.
    I tried upping the driver demand tables to no avail. Here is a pic of the screen-you can see that it stayed at reduced throttle after the 2-3 shift. I havent changed the demand tables back yet to make sure thats why. I think its going to run pretty good once I get the tune squared away-fun little car.
    Tuner VTuner's Avatar
    Feb 2008
    Vermont
    56
    It is possible - read the help section that Chris wrote for E78 tuning for some hints.
    you can do this with the tables that we have access to now:
    Yes, that is 22 lb/min airflow in the Cruze 1.4T at 26psi boost
    I might have a few additional mods
    Cheers,
    Brian
    2011 Chevrolet Cruze LT: 15.110 @ 89.380 MPH
    Vermont Tuning LLC
    1806 Sweet Hollow Road
    Sheldon VT, 05483
    Ph: 802-393-7305
    email :[email protected]
    Website: www.vtunersaabs.com
    www.vtunerperformance.com (Now Live!)
    Jan 2009
    Kalamazoo, MI
    14
    Still Learning this myself, Ive never tuned a torque management based pcm before. Just by reading the "help section" , try logging with this config file. I just went through and added most of the pid's in the help section. This is the config file I have been using.
    Quote Originally Posted by Regalgse View Post
    Yeah this is my first time messing with a newer PCM. Lots to learn, for sure! I loaded this config you posted and drove around the block to test it out. I am getting really "jerky" graphs, like the computer is having to think about too much stuff at once?
