Just build a 408.
243 PandP
FAST intake with 102TB
54-459-11 cam 231/239 .617/.624 +4
12:1 on 110
It's in an offroad race car. Full manual 4L80 with no in gear/park outputs.
Running SDOL. No O2s, no maf.
Slowly working on some VE by doing 3rd gear pulls up and down my 1/2 mile driveway. I guess I'm getting there all though it's not exactly smooth by any means.
I'm having problems with off idle to anything over 50% throttle. As long as I crack the throttle about 10% then go over 50 100% it'll pull on up but anything over 50% from idle it will just bog down and die. How am I supposed to get a reading to adjust anything? The numbers that are on the VE right now down there are after me just shooting around trying to find something to make it run.
I do have a decently strong idle at 1000 rpm (which is fine that high as I have to run hydraulic pumps to run the full hydraulic steering) with IAC counts at around 70 at idle. Although I'm not totally sure how I got there at this point and not totally sure which idle parameters I even need to be concerned with in SDOL...?
I did do the TPS reset after adjusting the throttle blade open a bit which worked fine....sometimes. Randomly it'll go back to around 1 or 2% open again. Seems if I cycle the ignition and run the throttle blade a time or two it'll reset to zero and run back to idle just fine. Haven't found a reason for it happening though. Thoughts?
I guess if anyone could take a look at this tune to identify anything I have in there that is ridiculous or that I've over-looked I'd appreciate it very much.
Let me know if more information is needed.
Thanks.
