Results 1 to 6 of 6
Thread: PLEASE help with my tune. Needs Review. LSX454
    Aug 2012
    Canada
    3
    Hello Guys, I have someone doing my tune and i need help. Here is my .hpt tune, please let me know if there is anything wrong with it. I have made some adjustments based on feedback i have gotten on this post and through PM's. Thanks again!
    2010 Silverado 1500 2wd
    GMPP LSX 454 Crate Motor
    FAST 102mm Intake
    NW 102 TB
    American Racing Headers
    PATC "Phionex" 6l80E
    Circle D Specialties 3700 Stall
    TCI Flex Plate
    3:42 Gears
    Has No Cats, But has Upstream O2 Sensors Installed
    Advanced Tuner vette_c6's Avatar
    Jun 2008
    Kuwait
    390
    need to know what is your engine compression
    what is your bore Size
    Crank Size
    Piston +10 or -10 whatever
    your head what is it
    72cc 70cc 68cc
    when you start does it start normal or not ?
    do you have a scanner log ?
    after i have all of these answer i will download your file and give u a hand
    good luck
    specialize in: V8 Tuning (Kuwait)
    Abdullah Al-najdi
    00965 99369929
    www.youtube.com/alnajdi83
    Tuners ! Quit Raping your PE TABLE !
    instagram : alnajdi83
    best number in 1/8 mile 4.54 ( My Driving + My Tune ) !
    Aug 2012
    Canada
    3
    LSX 454:
    11:1 Compression
    Bore is 4.185 x stroke 4.125
    Pistons are stock size
    Crank is GM p/n: 19170391
    Combustion chamber on heads : 70cc
    2.20 intake / 1.61 exhaust
    Cam is 0.635 intake / 0.635 exhaust
    236deg intake duration / 246deg exhaust duration
    The truck starts normal when cold, but when it warms up you have to give it throttle to get it to run, and then it will find idle and be fine. But any slight throttle when its warm and it will begin to surge, sometimes stalling.
    Hope that helps!! and send me a config file if there are sertain PID's u want to see on logs. Im still very new at this. Thanks alot!
    Aug 2012
    Canada
    3
    Truck (Blacky)
    Here is my truck.
    Dec 2009
    Slave Ship
    199
    ETC Area Scalar needs to be raised to around 7300
    PE Enable TPS is too high.
    I'd zero out PE Delay RPM.
    Why is your Stoich value set at 14.97? and I hope you're not tuning this thing by adjusting your PE table.
    Jun 2008
    Kuwait
    390
    this is a file on your file
    you can compare what i have done
    if this one didnt workout
    shot me with your Stock file car
    by the way ,, you need bigger fuel injectors
    better fuel pump
    i dont think the silverado fuel pump will handle this power
    adjust your windeband so we can read
    good luck
    Abdullah Al-najdi
    00965 99369929
