OK, since I finished how to tune throttle, now it came into SD tuning, faster than I thought.
Today I found my MAF is dead, so I disconected one, hoping car will drive as with. First I got 102 error and 2106, disabling 102 cured problem.
So i was driving in SD
Quite good anyway. But I thought it will be better, since I already tuned LWFM tables. But I'm 20% off at idle in rich direction, 0% im middle load/rpm and about 20% lean at WOT. So what's wrong? I started tu tune LWFM, no success, MAP at zero airmass, no success, map per airmass, no success. All this tables helped drivability in SD mode, but non of them changed FUELING. So finally I zeroed all of them, and guess what... I'm still driving without MAF, and same trims as above...
This directs me to thing, that LWFM table is somehow helper for real Apha-N table, MAP or airmass tables too, and real ALPHA-N Table is missing.
See attached log, driving with all SD tables zeroed...
sd at 0 test.hpl
