GTO Speedo Help needed
I recently installed some 4.11 gears into my 06 GTO and have ran into some difficulties calibrating everything to work properly. I finally got my speedo on the dash to display correctly, but now when I log, the ecu is telling HPtuners that I am only trapping 49MPH. But in actuality, it was around 110.
Please advise.
Attached are the log and the tune as well as my config. My afr display setup is a bit off in the log, but the gauge reads 12.5 at wot.
DFCO longer.hpt
no knock vs fox.hpl
GTO config 2.cfg
I would really appreciate any help or insight you guys may be able to toss my way. Thanks
-Chris
Abagail has: Full 3.5" dual exhaust w/kooks headers and Dynomax bullets, Svede , Full Suspension, 23X .600 lift Comp Cam, Mild Head work, Gforce 9" 4.11 Gears, Ported Manifold and TB, Stage 12 Fuel System
New Cam and Exhaust:
https://www.youtube.com/watch?v=DbAK8nK0Mcc
Why did you change the VSS Pulses per rev to 40? It should be 17 for a 6 spd. Did you also change your rear tire dia? If not, return the tire dia field to stock.
Russ Kemp
I will try the pulses change, and I did change the diameter, and the stock tire size was actually off by a hair.
