Results 1 to 8 of 8
Thread: programmable Autometer Speedo ppm ???
    Dec 2011
    5
    So I have hpt calculating my VSS for tire/rear end. This effectively puts out the 4000 ppm to my speedo from the ECU, correct?
    The question is, prior to having hpt I programmed my Autometer gauge to approx 3800 ppm due to a driving test per Autometer.
    Should my speedo be set solid at 4000 ppm and make all my calculations go through hpt?
    Aug 2012
    Minnesota
    13
    my limited understanding is that your gage should be set to the same number that the ecu is putting out. It might be easier to change what the ecu is putting out per mile compared to letting the gage try to re-learn and hoping that your reflexes are quick enough to push the button at exactly 4000.
    1968 GTO - 2000MY LS1/T56, Texas Speed 224R cam, edelbrock A-body Swap Headers, painless harness, 3" exhaust with x-pipe.
    Advanced Tuner oakley6575's Avatar
    Aug 2011
    421
    Quote Originally Posted by wade70ss View Post
    I would think yes. It has been a while since I programmed my autometer but I know it is usually off by 3-4 mph. I am going to reprogram it this week and see if setting it at 4000ppm corrects the speedo.
    2003 Chevy Silverado Daily Driver, 408 Iron Block,
    LS3 Heads/Intake, 231/239 114, 4L80e, Yank SST 3200.
    Mar 2010
    227
    When I did the autometer speedo in my mustang coupe I just did the drive procedure they asked for and it worked fine and was with in 1-2 mph.
    1993 reef blue Mustang coupe
    Ls1 conversion
    1 7/8 cooks headers
    AFR 205 heads
    Fast 92/92 intake
    PAT G./ EPS Custom cam 230/234 .600”/.602” 112LSA +2 advance
    century Built 4l60e with Circle D 3500 converter
    4.11 gears
    Dec 2011
    Melbourne, Australia
    82
    programming doesn't matter, run the 2 mile calibration for the autometer gauge, providing you have the vehicle speed sensor programmed correctly in the ecu then everything will read the same. regardless to you programming of the ecu the autometer gauge will read correctly after the 2 mile calibration
    stock 99' LS1 + powerglide
    gt42 a/r 1.06
    #80lb siemens @ 43.5psi rail pressure on E85
    return fuel system runing 1:1 FPR
    aeromotive A-1000 pump
    2 bar SD tune
    Aug 2011
    421
    Quote Originally Posted by vltrb-0 View Post
    Question is, can we program the auto meter to 4000ppm like the computer states and it will read perfectly?
    Aug 2011
    421
    Looks like the answer is yes boys. If the pcm is programmed for 4000ppm, then program your auto meter to 4000ppm and it will be money. Just verified it on my truck
    Dec 2011
    82
    Quote Originally Posted by oakley6575 View Post
    yep you can do that, the only thing im not 100% on is if you have previously programmed your autometer gauge can you do a factory reset to 4000ppm
    i have the push button program type and im not sure how to set to 4000ppm
    you must keep in mind that 4000ppm form your ecu is only as accurate as your vss input
    gt42 a/r 1.06
    2 bar SD tune
