Is there a know way to log A/C pressures from the scanner? I can only see a way to log in volts. But is there a way to log the high and low side pressures in psi?
2003 Chevy Silverado Daily Driver, 408 Iron Block,
LS3 Heads/Intake, 231/239 114, 4L80e, Yank SST 3200.
On trucks no they only use a switch. Most cars run a pressure transducer and can read high side pressure.
1997 Trans Am WS6 - LS1 swap - TR224 - Pacesetter Longtubes - Yank SS3600
- 3.42 Moser 12 bolt - Wilwood Brakes - HP Tuners tuned - P1SC-1 Procharger
depends on ur wideband put log pid 7101 thats ur ac pressure
00' WS6 370/PT4788/TH400
99' T/A N20
sorry thought u had an fbody not sure on the mid for the truck. if you hit the ? mark when your in user defined it will show the right number for that
99' T/A N20
