Im working on trying to speed density tune the VE table on an ls3 headed 408 build with a loose 4000 stalled th350. part throttle cruising looks pretty close but as soon as I put a little load on it like with the brake to get some hits in certain cells it looks to lean way out and gets sluggish. The VE table looks like the values are already pretty high. the only fuel pressure guage on the car is under the hood so i can't see it while driving.
Im posting a couple of logs and tune files as I made changes.
Let me know if you guys see some thing I missed in the tune to set it up for speed density tuning the VE table. The IAT is pretty high also not sure if this could be the issue. the car has a aeromotive a1000 pump with the fuel pressure set at 58 psi and has their regulator on the rail with fast fuel rails.
The car has 10an line ran from tank to the pump and 8an from the pump to the front of the car with 6an return.
here are some specs on the set up
PRC cnc ls3 milled .030 headed 408
238/251 .615/.632 114 cam
stock ls3 intake and ls3 injectors
