I have read and seen it done both ways. How do yo guys do it? Do you guys just disable it in the lower rpm?
1993 reef blue Mustang coupe
Ls1 conversion
1 7/8 cooks headers
AFR 205 heads
Fast 92/92 intake
PAT G./ EPS Custom cam 230/234 .600”/.602” 112LSA +2 advance
century Built 4l60e with Circle D 3500 converter
4.11 gears
For me, it depends on what I'm trying to tune. If know i'm not going to go WOT then I disable pe. If I'm doing more than part throttle tuning, I leave pe enabled.
2003 Chevy Silverado Daily Driver, 408 Iron Block,
LS3 Heads/Intake, 231/239 114, 4L80e, Yank SST 3200.
Ls1 conversion
1 7/8 cooks headers
AFR 205 heads
Fast 92/92 intake
4.11 gears
Yea for part throttle, I would disable pe knowing you won't be in any high load situations. That is just my opinion though
I would not disable pe, I would filter it out in your histogram.
That is a good idea. Never thought of doing it.
How do I filter it out?
Ls1 conversion
1 7/8 cooks headers
AFR 205 heads
Fast 92/92 intake
4.11 gears
filter it using commanded afr or commanded lambda. only take readings when cAFR or cLambda is at stoich. If it is not commanding stoich at operating temp, then it must be commanding PE, right? assuming you have the modifiers like COT, Dod, DFCO, etc etc disabled while tuning.
you can have one histogram for stoich tuning and another one for PE tuning. heck, you have 10 or whatever, use them all. you can tune part throttle, wot, idle, timing, etc etc at the same time just by setting it all up right before you start.
If you do your testing under the right conditions, it shouldn't matter. Just log your error as the ratio of delivered lambda over commanded lambda and that should give you the correction factor you need. It doesn't matter if you have 1.00/1.00 or 0.80/0.80, you get the correct correction factor...
In controlled environments (dyno cell ) you can disable the PE and go about your business as usual.
If your not in a controlled environment (on the street) leave it enabled and filter the error as stated above.
