I have a mildly modified crate LS7 in a 67 Camaro with the GM controller kit 19166567 using an E67 ECU. This harness has a single fan relay that takes a ground signal from the ecu to turn it on. I cannot get the ecu to turn on the relay no matter what I do. I have tried manually turning on the fan in the VCM scanner and still no output from the ecu. Everything else seems to be working fine. The relay and wiring are fine. I can get the relay to come on if I touch a test light to the terminal that the ecu should ground to turn it on and the fan works.
Please help. TIA.
