Results 1 to 4 of 4
Thread: Quick question, need suggestions.
    Senior Tuner IDRIVEAG8GT's Avatar
    Aug 2010
    Roswell, N.M.
    1,956
    I recently tuned my buddies GMC Sierra.
    All was good for a few days, then it came back to me with 2 rear O2 sensor high voltage codes. I simply disabled the SEL checks as soon the cats are going to be gone. However now I noticed whèn logging the truck, as soon as it hits PE OR I force Open Loop with a small load, Bank number 1's O2 MV hits the floor, 60-70MV (lean) and stays there until it goes back into Closed Loop.
    The other is reporting ~890 MV as it should. WBO2 confirms that this is correct with one bank at1 15.3 AFR, and the other bank at 12.5 AFR. No misfires are being reported. So..... would you guys say that the cats are plugging/plugged or something else is going on?
    Thanks for any input.
    618/618 motor
    906/862 spray
    Aug 2010
    Roswell, N.M.
    1,956
    Found the problem, yes car was plugged which in turn screwed up the O2 sensors.
    618/618 motor
    906/862 spray
    Nov 2007
    Minnesota
    555
    Glad I could help
    2012 Chevy Cruze A6 1LT RS
    Formerly - 2004 GTO, 2002 Z28, 2007 Colorado, 2008 Silverado
    Aug 2010
    Roswell, N.M.
    1,956
    Hee-haw
    618/618 motor
    906/862 spray
