Results 1 to 15 of 15
Thread: 2010 LS3 E38 Table Errors
    Senior Tuner 10_SS's Avatar
    Mar 2012
    Detroit, MI
    1,320
    "Try with smaller values for the enable TPS. From memory it's the same weird ETC % area - idle offset % the LS2 uses. Ie. You need to set it to values like 15-20% for tradtional TPS/ETC% of 40-50%"
    On my 2010 Camaro LS3:
    Actual:
    30% TPS PE = 60% in the log
    5% TPS PE = 33% in the log
    My questions:
    1) Has there been an update to this mis-calculation? From what I can tell this is carryover from LS2.
    2) What other tables list incorrectly?
    Apr 2007
    1,104
    also something else to add to this fun.
    apparently with the newest beta the map sensor value reads half of what it is really at.
    three 07+ trucks now i have logged have all done this.
    The most hated, make the most power.
    93 Ranger. 5.3 D1X. 1069hp.
    its not a miscalculation, the variable used for PE is not TPS%, its % throttle area without the idle component.
    I count sheep in hex...
    Mar 2012
    Detroit, MI
    1,320
    Area47: From what I can tell my map reads ok and I have the current beta.. 660?
    Chris: I'm confused as the titles for the values list TPS. What settings do I have to change/log/view to see my 30% values listed in the .hpl file?
    I just want the PE log file to match the .hpl listed settings. Any way to do that?
    the value GM uses to determine PE TPS is not available in the scanner.
    Nov 2007
    Minnesota
    555
    Do you know the exact calculation by chance?
    2012 Chevy Cruze A6 1LT RS
    Formerly - 2004 GTO, 2002 Z28, 2007 Colorado, 2008 Silverado
    post your OS ID's and i'll add it as an MPID to test.
    as i said above, generally it's the % throttle area with idle area subtracted.
    on newer ECM's like the E78/39 they have gone back to a more simple pedal %.
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,860
    What's the difference between a PID and MPID?
    http://www.dsxtuning.com
    Just say no to bull s***.
    Nov 2007
    Minnesota
    555
    12617631
    Advanced Tuner Redline MS's Avatar
    Jun 2006
    New York- South Florida
    536
    The "M"!
    Yeah what's the difference?
    Full Service GM Late Model Performance Facility
    www.redline-motorsports.net
    Follow US on FACEBOOK!
    Follow us on Instagram! redline_motorsports
    Mar 2012
    Detroit, MI
    1,320
    Quote Originally Posted by Chris@HPTuners View Post
    12637084
    its just our name for PIDs that reference direct RAM addresses. Memory-PID.
    Mar 2008
    St. Louis, MO
    4,860
    Quote Originally Posted by Redline MS View Post
    The "M"!
    Smart ass.
    2.23.731 (tomorrow) will have a new PID called "PE TPS" for 12617631 and 12637084.
    give it a try
    Mar 2012
    Detroit, MI
    1,320
    yea that will work! Thanks allot. I just ordered a whipple.. so this will help very much! Much appreciated.
