Which PCM do I need
I currently have a 2002 suburban PCM in my rx7 and I was running a 2bar OS and now want to make more power. I was told by the support guys at hptuners my PCM won't support 3 bar OS what do I need to run a 3bar?
The pcm for that vehicle should be just fine. You'll probably need to change your base O.S.. I can help you with that if you need it.
It's a Mazda rx7 with a 6.0l Escalade engine The PCM I have won't support a 3 bar unless I can change the OS on my current PCM. What u mean change your base OS?
