Just completed a LS1/4L60e into a '72 Vette and the trans is not responding to the computer tune. Engine runs great but the trans is not shifting. The car has been to the trans shop and they hooked the trans up to their scanner and shifted the car through all the gears, so the trans has been eliminated as the issue. When looking at the transmission though the scanner they get nothing. No VSS signal, a default 32 degrees for trans temp and nothing more. I do have 12v to the trans so the power is getting to the trans, but the computer is doing nothing with it. There are no codes on either engine or trans. Basically the transmission can be shifted manually into 2nd and Drive, but no 1st and no OD. Wiring seems to be fine...which only leaves the tune in the computer to be the issue. Any help guys? I didn't do the tune, but rather a friend of mine, and he says it was done by the book. I do know a few things...the PNP wire is grounded-out, per what he read to do. The TCC switch is hooked-up correctly. The shift selector display, where the original 2000 Camaro would show what gear the car was in on the display, has been turned off.
Engine and trans are out of a 2000 F-body. Thoughts? I'll take any guesses at this point. Thanks!
