Results 1 to 4 of 4
Thread: reduced power mode after maf tuning
    Nov 2011
    6
    this is a mostly stock 03 silverado 5.3
    truck has long tube headers , recently installed bbk 80mm tb .
    after trying to tune maf it comes up with reduced power mode .
    someone want to check tune for something i may have missed ?
    thanks in advance
    Dec 2009
    820
    post a log of it entering REP
    Tuner seven ends's Avatar
    May 2007
    Houston, Tx
    105
    Minor but you might try adjusting the scalar from .0208 to .0198 (78mm to 80mm TB). Would normally need to retune afterward. Also do a compare to your stock file and open the MAF airflow table and look at delta screen. You have suspect areas between 3250 and 3750, 5750, and 7750+ hz. Also wise to run RAF tuning following other changes. Good advice earlier to get a log file to get real help in pinpointing the problem. Cheers.
    RIP 2006 Avalanche 4WD; LS2 390 block; Mast LS3 heads; L76 intake; PT88 Turbo; eBoost2; 232/232-CL113; ID1000, Meth, KB BAP, LS3 TB; DRX X-Link; 2-bar+100mm;Maf; 4" downpipe to 3" twin exhaust; Xtreme Built 4L65e w/ billet shafts & Circle D triple disk; CSR flexpate; custom driveshaft; Truetrac; Trucool 40k; Autometer gauges; AFX WB; Viper Alarm, SSBC Big Brake Kit, AR Hankook 20's.
    Advanced Tuner blownbluez06's Avatar
    Jan 2008
    Forney, TX
    755
    some things in the tune that can cause REP:
    Min/max MAP values in the 106 tables (engine diag)
    exceeded calculated airflow tables in the 1514 table (easiest proper way to fix that is to raise it incrementally until it goes away)
    External causes are: throttle body issues. Anything physically resisting blade movement, TB unplugged, TAC module defective, TAC module power or ground issues, defective TPS sensor, Defective accelerator pedal assembly.
    Dallas Performance LSX434, Procharger F1X, FIC 2000's, Alky Control, Victor jr., Nitrous outlet direct port, RPS HD Triple Carbon, DSS shaft, RKT56 ZR1 trans, RPM Quaife diff, Lingenfelter mini-tubs, 1060RWHP SAE on boost and 1250 on 1st nitrous pull. New blower #'s pending
