Results 1 to 8 of 8
Thread: LNF weird command lambda
    Advanced Tuner projectlnf's Avatar
    Jun 2012
    warrenton va
    479
    when im cruising i see my commanded lambda hit around .93 then a sec later it will go to 1.04? is it just me or is it suppose to be doing this i posted a log for you guys to take a look at any input would help!
    thanks!
    Edit: its starts around 5:27
    2003 Ford excursion 6.0 PSD
    No limit intake
    Straight pipe
    Studded
    EGR delete
    KC billet single plane compressor wheel
    Self Tuned
    XDP Regulated return
    RDP Fuel sump
    AEM progressive water meth
    Custom suspension air bags
    8" lift
    35" tires
    Dec 2008
    Nevada
    4,452
    they look like 02 tests, notice how the commanded goes rich then lean and the 02 follows it somewhat closely.
    its not a problem as long as its not that lean under boost
    Jun 2012
    warrenton va
    479
    ohhh i see i was kinda confused but thanks man hows the lhu coming?
    No limit intake
    Straight pipe
    Studded
    EGR delete
    Self Tuned
    RDP Fuel sump
    8" lift
    35" tires
    Dec 2008
    Nevada
    4,452
    I'm at Buick dealership right now verifying other components to make this go easier
    Jun 2012
    warrenton va
    479
    ohh cool deal man cant wait to see that thing hit the road! mine is actually getting to be ridiculously quick lol
    No limit intake
    Straight pipe
    Studded
    EGR delete
    Self Tuned
    RDP Fuel sump
    8" lift
    35" tires
    Dec 2008
    Nevada
    4,452
    It's gonna be a while the battery is upfront in the regal this may require alot of parts and harness modifications. I'm gonna try to activate the ecu solo via harness and download the information to find the proper year to look at the correct diagrams.
    May 2011
    Québec
    36
    I notice this on cruise control for the LNF
    Boost Lover
    Jun 2012
    warrenton va
    479
    i only wish you the best of luck sir!
    No limit intake
    Straight pipe
    Studded
    EGR delete
    Self Tuned
    RDP Fuel sump
    8" lift
    35" tires
