I wan't to log the output voltage of my Fuel Pump Speed Controller.
Has anyone successfully setup a voltage divider circuit to reduce the 12v signal to 0-5v range?
Do I need to take into consideration any amperage draw from the EIO on the interface?
I found this post on LS1 tech
http://ls1tech.com/forums/pcm-diagno...resistors.html
which refered to this document from innovate. See Last Page.
http://www.innovatemotorsports.com/s...MA2_Manual.pdf
