Results 1 to 5 of 5
Thread: Custom SD OS
    Dec 2008
    on the Dyno
    1,825
    Custom SD OS
    I have tuned a few car's here lately that have had some really weird results with the custom OS's. Seems like the car's with boost and stock OS's run much better with less hickup's than the custom OS's have. Modifications to the VE table in some instances show's no change in physical fueling. Just wondering if anybody else has noticed the same thing with these E38/67's.
    From now on I'm using all stock OS's for tuning until something is done with the custom OS's as far as stability.
    Located in Central Kentucky
    ShorTuning
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,261
    Nope. Haven't heard of any issues with them that weren't user error.
    Tuner 4evervette's Avatar
    Jan 2008
    dyno room
    169
    slightly off topic: when do u guys will have COS for E67 os 12628912..
    specialize in: V8 Conversion & Tuning (UAE- DUBAI)
    supercharge installation
    Salah clutches for Nissan, Toyota and GM car
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,859
    Are you setting all three VE tables to the same?
    http://www.dsxtuning.com
    Just say no to bull s***.
    Dec 2008
    on the Dyno
    1,825
    Yep sure did set all VE tables each adjustment. Maybe I had an issue with this one particular OS cause I've used them with success before but this one particular car ended up picking up 90rwhp with nothing other than the stock OS re-applied to the tune and using EQ-VE and MAF. I was using the SD OS with the MAF also and both were calibrated individually. This was a 2008 C6Z with a D1SC on 9psi. Made 625rwhp DJ-248 with the custom OS. Ended up making 715rwhp with the stock OS.
    I'll send support an email to see if there is something going on we can't see.
    ShorTuning
